paul s
- 625
- 6
- Nov 17, 2002
kingston,
ON, Canada
Here is my latest purchase
Evo3 7bolt oil housing and Earls oil cooler(-8lines)
The cooler bolts right up but you need to purchase 2 new bolts as the oem don't fit(1 is too short and the other too long). You also need to drill and tap(1/8NPT) for the oil sender unit. You need to remove the crank and water pump pullies to take the timing cover off. 3(OFH) bolts are exposed but one is under the cover.
