pimpinboudy
- 48
- May 2, 2004
lambertville,
Michigan
Here is the list so no one has to go to my profile and check on my mods. here is the delemia: as you can see i have a 60trim. it is winter here in MI. and i haven't installed it yet. i was looking for a little help from the community. i talked to FP and they told me i had to go to an external gate if i wanted to run a big ball bearing turo. i would like to run the SBR GT13 or the GT35 internal. the reason is Money and Money and oh yeah More Money. would i be able to run the internal gate with a good amount of success or would i have to go with the external setup. i'm not new here or anything so plz don't criticize me. i just want to be able to push the turbo as much as it can handle or so with out using an external gate. Plz a little help would be greatly appriciated.
James
-K&N Cone
-Upper I/C piping
-Lower I/C piping
-1G BOV (Crushed)
-Dejon Tool Intake 3"
-Polished head cover
-Slim line Fan
-Accell wires
-NGK Cold Plugs
-650 Injectors
-255 Walbro Fuel Pump
-PT&E 60trim W/Texas Thrust Bearing(internalgate 38mm)
-Evo O2 housing ported to 3in.
-DNP Tubular Manifold
-Act 2100 Clutch
-Manual Boost controller (Hallman)
-Apexi N1 3" DP
-Apexi N1 Cat Back 3"
-Greddy FMIC
Engine:
6Bolt 4G63,Three Layer Metal Head Gasket,3 Angle Valve Job,Crower Springs,Crower ss Valves,Crower Titanium Retainers,HKS Cams 272's,New Upgraded Lifters,ARP Fasteners
New Guides,New Valve Stem Seals,ARP Studs,Fidenza Cam Gears,Eagle Rods,Ross Piston
James
-K&N Cone
-Upper I/C piping
-Lower I/C piping
-1G BOV (Crushed)
-Slim line Fan
-Accell wires
-NGK Cold Plugs
-650 Injectors
-Act 2100 Clutch
-Apexi N1 3" DP
-Greddy FMIC
Engine:
