talonwrx2002
Banned Member
- 50
- Dec 30, 2004
Rockville,
Maryland
How hard is it to do ? How do you get the pistons out of the cylinder??
talonwrx2002 said:How hard is it to do ? How do you get the pistons out of the cylinder??
1fast97gsx said:don't even remove the intake and exhaust manifolds from the head ... pull it all off as 1.
Never worked on a engine a day in my life, but with a Chiltons manual I managed to take the engine apart and replace many gaskets / belts, and best of all, the car still runs!babell2 said:I don't want to sound rude but---- If you don't have a manual stop now and get one. It will greatly improve your odds of putting the engine back togeather and have some kind of relyable build up. The manual will have all the basic informaton on engine maintenance that you will need. If you get into mods and upgrades--- Now its time to hit the forums
talonwrx2002 said:Thanks guys I do have a manual ... I have alldatadiy.com but this is what it says..............
Remove top ridge of cylinder bores with a reliable ridge reamer before removing pistons from cylinder block. Be sure to keep tops of pistons covered during this operation . Mark piston with matching cylinder number.
I'm not so sure what the top ridge of cylinder bore is so yeah thats most of the reason i got confued?
any suggestions????
In ye olden dayes, blocks and rings were sufficiently mis-matched in metalurgy, and oils were bad enough that within 50,000 miles the rings would machine off enough of the cylinder wall to leave a ridge between the original bore's diameter and how much the top ring had cut the wall. Ridge-reaming used to be standard procedure. I've never had to, starting with engines from the sixties.talonwrx2002 said:Thanks guys I do have a manual ... I have alldatadiy.com but this is what it says..............
any suggestions????
