Verticaljump1
- 147
- 2
- May 8, 2004
cheyenne,
Wyoming
How do you eliminate fuel cut on a 1g with a maf translator v. 2.01? I think that's why the car sucks above 14psi, it's a possibility?
Verticaljump1 said:I'm pretty sure the problem is fuel cut now. Fuel cut kicks in at a certain maf reading I don't think it's related to injectors. Because improving injectors/fuel pump doesn't help. Any suggestions guys? What does fuel cut sound like? The car makes a rapid puh puh puh puh puh puh puh sound when it hits 14PSI or above, and under one run accelerating from 2000-6500 in second gear the car blew a puff of white or gray smoke from the exhaust as soon as it hit 15PSI.
