99EclipseGSX
- Oct 24, 2002
I was just wondering what is the max psi that i should run on a stock
T-25?
Thanks
Bryan
T-25?
Thanks
Bryan
, I think I am going to cry. This should be in the "Newbie" forum and noone can tell you what is safe. I don't mind helping people, but if I had a dollar for everytime I have seen this question asked on this board. They can only tell you what they think will be safe. All far's are different, but the rule of thumb on a t-2slow is anything after 15lbs of boost is just hot air and not worth the extra 5-10 you may get out of it. You will be making the turbo work alot harder and it will die alot faster than it would normally.
Happy boosting
I would just disagree about running more than 15lbs of boostOriginally posted by larryd
i love throwing this in after people say not to run more then 15psi
dyno 1 was 14lbs
dyno 2 was 18lbs
dyno 3 was 22lbs
Stick to 16ish on the street, and datalog if at all possible to make sure that is the right number for your individual setup...
