cant pass 5psi.......... whats wrong?
kpjoek83
Aug 4, 2004
chicago, Illinois
cant pass 5 psi(turbotoosmall t25)........... whats wrong? i checked for leaks but there is none. :cry:
check ur vaccum lines... if you have a greddy type-s, ensure you have a line tapped to it... double check if you lines are CORRECTLY put together... you might of reversed your lines... maybe?? i dunno.. but hope those ideas helps...
check for a properly working turbo [ i.e., check for blown seals, little/no shaft play, hooked up WG ]
check for boost and vac leaks, check WGA for movement, make sure your WG arm is NOT bent.
make sure your boost gauge is hooked up correctly.
Do a boost leak test. I had the same problem and found that my BOV was stuck open.
Make sure all your couplers are on tight on your uicp nad any other intercooler piping
