truwarrior
- 1,422
- 6
- Dec 19, 2002
Ok I got the RRE kit, everything is off and now I'm porting parts and going to be putting everything back togeather so.
Question 1:
I got the EVO III turbo to 02 housing gasket but the gasket block the wastegate path at both the turbo AND the 02 Housing...Should I cut the gasket so it matches the EVOIII wastegate outlet and also the 2G o2 housing wastegate path?
Question 2:
My RRE install kit came with 4 oil return gaskets. One is like vinal/rubberish and the other is kind of the same except it's wider and has a little dot at the side....it also has a ring in the middle of the gasket where the other set doesnt. Do I use both gaskets togeather? Which one goes on which side?
Thanks!
Question 1:
Question 2:
Thanks!
...I have black snots in my nose
