Red 2g GSX
- 86
- Oct 11, 2004
Orange Park,
Florida
I am putting in a 1g motor in my 2g GSX and i am having some problems wiht the cam angle scensor. (CAS) I read that you can "switch" some wires on the CAS and it will work but you will also have "random miss fires." I also read that you can build a circut board to serve as a translator for the CAS to the ECU to elimiate the random miss fires. I wanted to know exactly what is random miss fires and what it causes. Also has anyone built the board and used it? If so please post how it worked. If the board works would anyone be interested in buying some if i built them, so all you would have to do is plug the CAS in to the board and the ECU onto the other side. Well let me know I need help.
Thanks
Vic
Thanks
Vic
