Verticaljump1
- 147
- 2
- May 8, 2004
cheyenne,
Wyoming
Okay, I did a recent turbo swap, from a small 16g to a 14b turbo. I made sure everything was tight. Now the mistakes:
1.) My oil feed hose is rubber, and has 3 clamps to clamp onto the oil feed line.
2.) I filled the car up with too much oil, when I check the oil it was about 3/4" an inch above the highest mark.
3.) I only have two turbo-manifold studs in, the others are snapped.
4.) There is slight boost leak where the throttle body bolts to the throttle body elbow, around 2psi leak I think???
My car is only boosting at 5PSI in first gear, around 7-8 in 2nd gear, and about 10 in 3rd gear, wtf is wrong? When I drive it and park, I noticed big oil leaks (up to around a pint!), and the car smokes from the engine bay a little bit. THen when I was driving I heard a pop sound, then all of a sudden there is a crap load of smoke coming from the engine bay. I pull the car over, and check everything, and the lower intercooler pipe is soaked with oil, I mean I just squeezed it and I got oil all over my hands. Is my car not boosting the right amount because there is oil in the intake side of the turbo and in the ic pipes? Is my turbo ruined now? (I just installed a 14b w/ zero shaft play!). What do I need to do to fix this? I've worked so hard on this car and it's just not being nice back, I'm only 16 so time is limited due to school and work and I really need a car to drive. Check my mod list if they have to do with anything.
Feel free to email me at [email protected] with help, or call 307-778-7869, I really need this darn thign to run and boost right
, thanks~Brandon.
, thanks~Brandon.
