Direct waste gate/turbo hook up on my RS49
AL92
933
4
Dec 12, 2003
regina, SK, Canada
I am wondering what effect simply running a direct line for the turbo nipple to my internal wastegate will have on my boost.Currently my new RS49 is only getting about 10psi.Is the reason I have just hooked up a line directly.I have mbc and will add it back but was wanted to keep the boost down a bit.So the direct line puts it at minimum the wastegate is set too??
It will just run what the spring in the wastegate is at. So i would say that your safe to do this.
My wastegate arm is adjustable on my turbo, but that is how I run mine with no problems what so ever. Boost controler would just go in between.
