Whistling noise
venom2097
122
May 3, 2002
I just put a new block in my 2g, now under moderate to heavey acceleration I can hear a whistling noise, as soon as I let off the gas it goes away.
It could be the air being sucked through the turbo, but it didn't make that sound in the old motor.
mods: hks mega flow,hks ssq bov,16g,3in pipe
Any ideas what it might be?
Originally posted by OMN_DSM
It may be a boost leak, but I think it is pretty normal. How does your power feel? Why did you replace the old engine?
Mike
Where should I check for a boost leak?
power is low right now, new clutch so I lowered the boost to ~12psi. Replaced the old block because I broke a rod and killed the oil pump.
Build yourself a boost leak tester. There is a how-to on the vfaq. just need a few parts from Home Depot and an auto parts store. I can almost garantee that you will find leaks, I found them all over the place on my car. Good luck!
Mike
Some manual boost controllers use a bleeder hole. The XBC uses one too. When you start to pressure-ize your intercooler pipes via your turbo, the bleeder hole literally bleeds off boost. Its an insignificant amount, but it does make a SHHHHH sound different from the turbo spooling. Either way, you should def. get/build an intake tester and go from there. Good luck
Where is the Leak Detector FAQ??? I tried and couldn't find it last night...some of the links were not working either!!
The noise has stopped since posting this, so I dont know what it was and will never know.
Thanks for all the help anyway.
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
