Emissions queston?
SOURCE1064
954
Apr 15, 2002
Paramus, New Jersey
I was at my mechanic's shop the other day doing work (he allows a few of us to use the shop on the weekend when he isn't there, taking the huge decal off the hood, yes it's gone) and one of the guys there, not mechanic, said he didn't think I would pass emissions. If I have everything properlly tuned and I have a cat why wouldn't I pass, and do you guys think I will?
Mods:
Engine
J&E Forged Pistons 9.0:1 compression, .020" over-size
Eagle Forged Connecting Rods
Stainless Steel Valves
Titanium Valve Springs With Retainers
HKS Cams 264 degree intake and 272 degree exhaust cam
Slowboy Racing G60-1with 4" TO4ER compressor housing, ported with an adjustable internal wastegate with a 38mm flapper.
Fuel
Denso 720cc Injectors
Holley 255 LPH Fuel pump
B&M CommandFlo Fuel Pressure Regulator
B&M Fuel Pressure Gauge Set
Exhaust
GReddy Big Front Mount Intercooler Kit
GReddy Lower intercooler piping
GReddy Upper intercooler piping
GReddy type s blow off valve
HKS Super Mega Flow system
Road Race Engineering Extrude Hone Intake Manifold
David Buschur 2G Exhaust Ported Manifold
Burns stainless steal 3” down pipe Thermal wrapped
Random Technology 3” high flow catalytic converter
GReddy 3” Power Extreme exhaust
Dejontool 4 inch MAS inlet pipe
EVO III 02 Turbo Exhaust Elbow
Electronics
GReddy PRofec B
HKS Super AFR
Jumptronix Digital Air/Fuel Ratio Meter
GReedy 60mm Electronic Boost Gauge
GReedy 60mm Electronic E.G.T. Gauge
GReedy 60mm Electronic Oil Gauge
Thanks for any info
I think you should overall be pretty fine getting through, depending on state. The 264/272 combo isnt too bad for overlap and you have a random cat on there. Id say run it through as is and if you fail try some isopropyl alcohol in the tank. Good luck
