BCS free mod done, impressions
DieharD
39
Aug 8, 2002
Vancouver,
hey guys. just did the bcs removal free mod for stocker dsms. it literally took 5 minutes. i can feel it pull a little better which is expected but what was weird is that the stock boost gauge was reading less boost than usual when i was WOT approaching the red line. i heared that stock boost gauge is a pos so i wont believe it until i get real a gauge which is sometimes soon =).
Yeah, stock gauge is a "guess" based on airflow #'s
Expect a bigger gain from a BOV upgrade then the BCS mod --- when I didn't have a boost controller, I had to put that lil restrictor back in. Without it (and an upgraded bov) I was hitting 17psi on the T25
now thats weird because i already have a 1g bov and uip in place. i thought that it should not be hitting anything higher than 13-14psi. hmm should i put it back to avoid possible problems? im still running stock fuel system. hmm i also didnt hit a fuel cut when i was testing things out.
...your trusting the stock boost gauge. its not even a gauge. its an uneducated guess.
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
  • For sale 1g 1G Turbo Intake Kit
    Used 1G turbo intake kit. Fits on stock intercooler and uses stock BOV. Comes with the MAF and...
    • Badge023
  • For sale 4G63 Used FP 4G63 Turbo Manifold
    Used FP 4G63 Turbo Manifold removed from 1G Talon. Looks okay, needs a cleaning. Did not see any...
    • Badge023
  • For sale 2g Fiberglass Fenders
    2g Fiberglass fenders. Overall good condition. $50 + Shipping/FeesFor faster response Text...
    • 1SlowPOSEclipse
  • For sale 2g 97-99 Mpi relay
    2g. 97-99 Mpi relay. Many don’t realize the later 2g doesn’t use the same mpi as the 90-96...
