Hobbes =^.^=
- 663
- Jul 15, 2002
I am planning to have this swapped into my 2g along with the 1g head, and getting the engine built. So I thought that a bare block would be a good idea. However I talked to the people who were going to help me swap this motor in and they said it would not be a good idea since it will be missing alot of bolts and other things. And in the end it will ultimately cost more. Should I go for it or not?
Also how difficult is it to build the engine yourself. I am no mechanic, and don't have in depth knowledge of these engines. Instead of the money going into labor, I could use that to upgrade some more. Can someone with just a manual/guide do it? I would just like to know since I would like to save some money is possible, and also learn something in the process.
Thanks for your help.
. But the way I look at it is when was the last time you saw a guy put a 2G head on a 1G. Anyone have any flow numbers for these heads? I think the flow charts would probably help.
It kills the flow of the head regardless if its ported or not.
