Bohrn
- 1,247
- Apr 28, 2002
Chilliwack,
Well, I just got a custom 3" mandrel bent 304HT stainless exaust with a matching cat and Borla muffler. Big difference, nice workmanship, but I have a huge problem with boost creep!
I can only run a vacuum hose from the turbo nipple to the wastegate nipple with no MBC. This equates to 10.5 psi at most for normal use, but when I really get on it, it will creep over 16 in 3rd or 4th gear. If I run my manual boost controller set at 15psi (or even 12), it is great for normal driving, but floored, and at high rpm the boost goes WAY too high, and I have to lift.
Yea it's ok for 5grand and up, at WOT, but any other type of driving, I have less boost than stock, and it is kinda slow.
So I figure I have to port my wastegate. This seems kinda scary to me, so any help, tips, links etc would be greatly appreciated.
Do I need new gaskets? Other stuff??
Oh and I got a new 2G manifold put on at the same time as the exaust, so the studs, nuts etc, are all new.
Please, any experience in this area would be great, as I only have the Haynes manual.
hehe, I wish I could spend multiple hours on my own projects at work.
