REDBLUR
- 220
- Apr 25, 2002
Alrite I installed a boost controller recently (home made off the net) and have a few questions. I am running the stock exhaust with a fuel pump rewire. I adjusted the boost to 15 psi(aftermarket boost guage). When I hit 15psi it holds for a couple of seconds and then tapers off to 10-12psi as i move up in the RPM range. Is this normal??? Or do I have a boost leak somewhere???
I am going to be making a leak tester and checking anyway, just wondering if the boost is supposed to hit and hold at the specific PSI setting throughout the whole RPM range (3500-6300RPM).
Thanx
Thanx
