N/A Head on Turbo block
qcdsmtsi
Aug 17, 2003
Bettendorf, Iowa
Question for you guys
Will a non turbo head from a 91 fit on a turbo block (92 6bolt)?
I have access to a parts car with a good head and I am planning on selling my 92 and just want to fix it to sell it.
The valves are also slightly different. The NA valves have a larger dip in them where the turbo valves have a slight cut out square section. I could take a picture if that'd help. Also, don't forget to take the plug out of the spot where the turbo oil feed like goes. Other than the valves and the cams, I can't think of anything different.
LOL, yea thats something ill make sure i get done!
So if I changed the cams and left the valves would it be ok?
Again looking for a simple fix
  • Wanted 2g ABS - Left side harness brackets
    Looking for the metal brackets for left side ABS wiring harness. Sensors not needed
    • Justin DuBois
  • For sale 2g 2GB CAS Assembly ( Complete )
    2GB CAS Assembly ( Complete ) $85 + shipping and paypal feesYou must be registered to see element.
  • For sale 2g 2G Clock Spring, Wiper Stalk, Turn Signal Stalk
    2G Clock Spring, Wiper Stalk, Turn Signal Stalk $35 + shipping and paypal fees* removed from...
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
