ChrisHKS
- 83
- Sep 28, 2002
To anyone with the AGP L2R turbo. How has the results been and what kinda power you makin with it?
Originally posted by Z1500
The L2R has gone 11's, but some good times will be comming soon now that the weather is cooling off.
Kevin
www.agpturbo.com
Kevin
www.agpturbo.com
Kevin
www.agpturbo.com
Originally posted by ILOSE
R U saying that the turbo will only run good in cool weather? I hope not, because all cars go through the same temps. Do yours have a harder time in, your experiences, in the heat. Is this an effieciency thing or what?
No that's not what I'm saying at all. All turbo cars run like crap in the heat. AGP turbo is located in the hottest inhabited city in America (Phoenix). We did run 11's first time at the track with the L2R, just after bolting it on. The car was not tuned very well and it was hot as hell outside. We'll put down some real numbers in the next couple months.
Originally posted by AWDGSXownsU
give me a month and you will see the L2r in the 10's. since i couldn't sell it and go bigger im saying #@%#@%#@%#@% it im going to go ahead and prove what this turbo can do. 10 seconds slips and 600 hp outta of that Biznatch. if you can wait a month ill send you some videos, timeslips, and dyno charts.
Manny
92 GSX
Originally posted by spooldswede
Otherwise, it looks like I'll go for the solid 20G turbo afterall... which will save me a lot of cash, and also peace of mind, since it's been proven many times!
Originally posted by GreenGSX
If peace of mind is all your after then go ahead and get the 20G. It will do everything they say it can do in the right hands. In the wrong hands it can be misery.
Your missing the point of the L2R. Sure it can run 30psi but its the boost response that makes it liveable. And don't be so quick to raise the BS flag with by throwing around the "20G is proven many times". Tuning a big turbo isn't for the weak of heart. It's tuff. Heck its tuff to tune a B16G if you don't know what your doing. I installed a ETE32 this spring and it took me all year to get into the 11's. All the while reading the mutt bashing and how this doesn't compare to this or that. I can tell you from direct experience racing against the L1R that AGP knows how to build turbos and the ball bearing center section is for real. There's a huge list of differences but how about never having to "no-lift shift"? Try that with a 20g and see how hard it is to get to the 11's. Ever autocross a car with a big turbo. I did and I would kill for 500rpm quicker spool.
The point is AGP builds great turbos and the comparison between the 20g and L2R is night and day. I'll bet you a $1 if you had a chance to sit in to equal cars, one with and one without BB turbos, you never go back to conventional turbos agian. That is unless all you plan on doing is rolling the car off the trailer at the strip....and even then AGP can get you a monster BB turbo.
Don't be a wuss and fall into the "nobody has numbers trap". Go back and search on the ETE32 and see what everyone said. Then check out how fast its going now. On paper the L2R is even meaner than the ETE32 and both are built with brand new Garett parts in TO4E housings.
By the way...what numbers are you running?
Tim
Originally posted by L2RTSiAWD
I know kevin is going to smack me for this
I went 22.xx@54mph on my L2R![]()
I wouldnt say that out loudOriginally posted by L2RTSiAWD
