95talontsi
- 274
- Jun 29, 2002
Princeton,
I am starting to go through the turbo selection process. What do you think is the max boost I can run, fully intercooled and with plenty fuel on an 2g early 95, with 123k miles on it. Compression is still good. clutch has been replaced and tranny built.
ps. is it true that a bigger turbo makes more "effcient boost" even at lower boost levels then a smaller one at the same psi???
Man, I couldn't repeat that if I tried.
