bog...10psi max???
9699gstconvert
May 3, 2004
austin, Texas
i've got a 2g gst ....i have this serious problem with my car...b 4 i installed a mbc to my car it was running about 12psi of boost but then after i installed it i couldnt adjust it to the right setting. so from now i my car consistently bogs when i floor the gas....is there a fix....i've tried putting the old hoses back to the stock 2g eclipse boost controller but it still bogs...plz help if you can thanks.
i dont htink i hit fuel cut because its only 10 psi and b 4 my car hit 15 psi easily,and all the plugs i double/triple checked those....but whats knock?
sometimes when i go into WOP the whole car seems like its about to shut down....it bogs so hard,and a bunch of black smoke comes out of the exhaust....and this all is with the normal stock gst BCS...now i have no clue whatsoever.....plz help if you can
