3" GM Maf with 4 inch intake
eclpsegsx12
214
Feb 16, 2003
Tucson, Arizona
Im getting a 3 inch maf to go along with my dsmlink for tuning but im thinking of how thats gonna work out considering my intake to my FP3052 or FP3065 is 4 inch?..Wont that be defeating the purpose of the 4 inch intake?....Ill be running a ADFX or SBR fmic kit fyi...What you you all do in my case?
run the GM MAF in the upper intercooler pipe blow thru style and run a screen over the turbo that eliminates everything or you can run an intake pipe
Blow-through setup or VPC. Just get some couplers and cut a length of the intercooler tubing and slap the GM MAF right in there.
-Groomz
Ya, thats what i may end up doing....Could someone tell me if the FP3052 is a 3 inch inlet?
  • For sale 2g Fiberglass Fenders
    2g Fiberglass fenders. Overall good condition. $50 + Shipping/FeesFor faster response Text...
    • 1SlowPOSEclipse
  • For sale 2g 97-99 Mpi relay
    2g. 97-99 Mpi relay. Many don’t realize the later 2g doesn’t use the same mpi as the 90-96...
  • For sale 2g 2g window moulding
    2g pass side window moulding. Rubber is in decent shape. Has one dent. Front plastic end cap...
  • For sale 2g Mahle Power Pak Pistons
    2g Mahle Power Pak Pistons, factory bore $350.00 Brand new with wrist pins and extra set of...
    • jmt2028
  • For sale 2g Water Neck/Thermostat Housing
    2g OEM waterneck and thermostat housing $60.00 In good condition, came off 1995 Eagle Talon Tsi
    • jmt2028
