focusedrage
- 1,053
- Aug 3, 2002
Laytonsville,
Maryland
Ok just the other day i added a 3" cat back system from extreme motorsports to the following mods:
Injen Intake
Magnacore Wires
NGK Plugs
BCS mod
Now the car is totaly different... i have to pushe the pedal down a lot farther to make it do what it used to, and i can just put the pedel at a certain point, it like stops revign up at about 4000... i mean when i want to go fast it works pretty good. WHat is the problem?
Did i shift the powerband?
Also when i put a boost controler and a gauge in will iu beable to kick up the boost enoguh to compensate?
Sounds great though, thanks for any help
Injen Intake
Magnacore Wires
NGK Plugs
BCS mod
remember that you need some backpressure so your intake valves can open up again. I would say that a 3 inch exhaust is meant for a car with a large turbo running higher boost. When you are actually cramming that much air into your engine than you should open up the exhaust.
