t28 fit?
herostar
1,929
13
Jul 24, 2002
Denver, Colorado
i was wondering if this turbo will fit
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=1858036960
i've seen a few of them on ebay for pretty cheap, and i'm gunna need a new turbo soon (I know, get a 16g or a fp big 28... but i don't have the funds...)
all I want to know is if it will fit w/o an adapter kit, and if it will give me much more power (like what psi) with supporting mods.
If you want to run 9's in the 1/4 mile. ROFLMAO!!!!!!!!!
All kidding aside I doubt that has a mitsu hot side so it won't bolt-up.
if it is a real t-28, you could just have the wheels out of it and put into the stock t-25 with some porting done to the compressor and turbine housings, as well as a rebuild kit. i wouldn't recommend it though, i had a friend try it and he had a defective wheel and pieces broke off and flew into the engine... a cheaper alternative to get you by is to buy or rebuild a 14b until you save up for a 16g or whatever you want, the 14b is better than the t-25 but lacks against the 16g, you may even find someone who'll practically "give" it away. and don't worry about kits to fit it if you're on a budget, the oil line is easy, seperate it and clean it out good with solvent and buy a 3/16 to 1/8 pipe thread adapter, (or whatever the size is i forget at the moment) for the drain, you gotta work the flange holes a bit but it'll fit, re-position the water lines (the 2g's fit) and buy new hoses and get a muffler shop to bend some pipe that'll fit from the outlet to the ic pipes, buy new exhaust gaskets then your done, i was in your shoes and the guys at the club dsm in florida put me onto the mod, and i'll be set when i buy the big 16g, but i'll definetly buy some kit parts so my warranty doesn't void http://www.roadraceengineering.com/2g16ginstallkit.htm
