Help w/ Brode UICP fitting...
CL MaNTis GST
775
Jul 16, 2002
Hey guys.. just got a used Brode UICP in the mail, and tried installing, but it did not come with the black elbow fitting that connects the pipe to the oem side mount. Any idea where I can get something that would work?
I've attached a pic of what the pipe looks like, I just basically need the black fitting at the end of the pipe... so that it allows it to connect to the side mount intercooler.
you guys that have this UICP, did yours come with this... if not what would u suggest using, and where did you find it? THanks!
Originally posted by boostineklipz
the black elbow that came with the pipe is what connects to the stock IC
You have everything you need, so go put it on. Here is a pic.
http://www.2muchboost.net/Members/member1/intake.jpg
whaa?? mine didnt come with the black elbow so i'm in a bind. I dont have something to connect it with. my question was where could i find something like this to connect it with. =/ this sux....
Boostin u arent listenin, he didn't take the pic, its a pic of what the brode uicp looks like.
anyway. Its just normal piece of rubber elbow u can probably pic up at home depot.
It's about 1/4" thick, 2 1/4" opening with a 45degree bend, 8 1/4" long on the outside.
dont forget to get the clamps, mine came with 3.
where did u get the bov by the way?
It comes with it when you buy it from Brode, I just got mine a few days ago and it came with instructions that list the part number for the rubber elbow, here they are:
Goodyear Item #60397 (Installs with the long leg toward BOV)
Gates Item #20748 (Installs either way)
That should help you out.
i said email david brode and how am i suppose to know he didnt take the pic....:dsm:
