head swap question
1fast97gsx
4,517
17
Jul 6, 2003
Orland Park, Illinois
I'm in the process of putting my engine back together right now and I'm also doing a 2g to 1g head swap. I have it all figured out except for the map sensor. I read that you weld a plate on the new intake manifold to mount the sensor. Do you just drill a hole into the manifold and then weld the plate and the sensor over it or do you cut out a section of the manifold and replace it with the plate and the sensor?
