custom oil feed like ?'s
babyman0737
86
Feb 6, 2004
Omaha, Nebraska
I'm working on a 14b swap on my 2g Eclipse. Does anyone know the sizes for building a SS oil feed line?
1. What length and -AN sizing of line?
2. What size and bend going to oil filter housing?
3. What size and bend going to 14b turbo?
So you mean to re-route this from instead of the head to the turbo. The turbo to oil filter housing? If so, I made my own since I snapped the bolt off in my head.
I turned the oil feed line upside down and cut the circle off that the bolt for the head would go to, then got a 6in. piece of high pressure hose and clamped it to the end of that. I took my oil filter housing allen bolt to the store, told them i needed a steel break line with that size fitting on the end, they found one, added on another piece to bring it to that size, then i just bent it and cut it, and connected that to the other end of the rubber hose.
That is my setup for now as i needed my car to run that day, and it has held up for the most part with no leaks or anything.
Hope that helped alittle bit?
Rob.
It is -4AN ss braid.
Just order it from AGP, FP, AMS, Turbochargers.com etc... It is around or under $40... Not worth the time.
I had a hose shop make me one but I was there having hydraulic lines made for work anyway so they cut me a deal.
that is also 4an.
I have an extra oil feed line and the fittings to make it work for you $50...I bought two of them on accident, from forced performance, I paid $60 and it's brand new.
