Which Manifold?
BoostNV
69
Oct 29, 2002
Hello,
I am looking to change my exhaust manifold and I was curious what everyone recommends? I plan to upgrade to a 20g later this year if that will influence which one I should select. Thanks in advance
Originally posted by BoostNV
Hello,
If you want to reduce spool up increase off boost response and flow like crazy up top. An equal length header is what you want. A ported 2G or evo manifold will work. However without ever trying something different like most have not. how can you give an accurate recommendation?
To date all the impressions of the dnperformance.com header have been very positive no cracking..ect
external gate version
my installed and jet coated version without the external elbow
Im not sure if dnp offers the jet coating through them. I think the cost for the manifold was $110
Did it really make a noticable difference with spool? Better transient response or the same? Thanks
There is only one other person that I know of that post on dsm boards that has the same turbo as I do. He has a 2G main and I have the dnp.His turbo spools at 3800 and mine spools at 3400.
What type of ignition are you using?? I have seen that setup before but have no idea what it is?
Its from buschur its a coil on plug setup
this one but im guessing it wont work for you turbo hehe but it will for mine :thumb:
