slikvik
- 93
- 3
- May 25, 2006
Prosser,
Washington
I have tried searching and have had no luck fixing my problem. It is not the average limp mode problem. The car will run great then go into limp mode (stuck in 3rd gear) after driving around for 5-10min. But if I pull over and turn the car off then on again, it will run great for another 5-10 min before going into limp mode again. I can do this all day.
So far I have replaced the ECU and ISC. The last ISC had a bad coil which burnt the original ecu. Even with the bad ECU and ISC I still had this problem. I was really hoping that replacing the ECU and ISC would have solved my problem, but it didn't. I have checked the ECU and ISC just now to make sure that they did not get toast again, and they checked out fine.
Logically I checked the TCU out, but it was rebuilt in 2006 with all new caps, according to the writing on the cover. The caps and board look brand new, which lead me to believe that it's not my problem. I tried pulling codes but it's really hard to tell with my digital multimeter if I even have any. There is no check engine light either.
Has anyone ever experienced this? I have checked for loose connections, and nothing. I have also checked the 10amp fuse by the kick panel and its also fine.
Any help is greatly appreciated. If you have suggestions on what I should check next I would love to hear it. Thanks.
