ypnas777
- 301
- 1
- Feb 24, 2003
North Andover,
Massachusetts
My tranny is slipping the 2-3 shift when it shifts anywhere after around 3k rpm's. The higher the rpm's, the longer it slips. So when I floor it, the rpm's go past the rev limiter and then it shifts. It is only the 2-3 shift though. I just finished installing a tranny cooler and lost quite a bit of ATF doing so. I've since added 2 quarts and the slipping continues. I am also having trouble reading the dipstick since it seems to give me different readings everytime I check and the white dipstick is just hard to read in general. Could under or over-filling the tranny cause this? I am thinking about just changing the filter and doing a complete flush with synthetic fluid and lubeguard. Do you guys think this will help? Keep in mind it was shifting fine before the cooler install. Thank You
