93 Auto questions (electrical)
jltcat
187
2
Dec 1, 2002
somewhere, New Hampshire
Not very familiar with this car and I have a few questions.
is the transmission capable of shifting manually (without any electronics)
also what is the factory stall speed on the converter
and is the ECU different from the 5 speed ecu
you mean shifting from L-2-D??? if so, yes it gives a pretty close shift
yes, it does use a different Ecu settings, it actual is set to 390cc injectors. Manual ecu is used for their stock 450cc's(this refers to 1ga and 1gb turbo models only)
by manual shifting, I mean shifting without being hooked up to the computer
98TalonTSi said:
No, you need some type of electronic controlling device.
like two toggle switches and about 6 feet of wire :D
I have been reading about your toggle switch setup on a couple of different threads and was just curious on how you made it.
On a side not, how come it seems like 93 autos have the biggest problems with the electronics?
the solenoid harness unplugs near the dipstick, you just put plug ends on the wire and hook 2 up there, then run them to the toggle switches and run power to the switches.
it's easy to show, hard to explain with words :)
  • Wanted 4G63 800cc injectors
    • DSM_Thorpe
  • For sale LC2
    Used LC2
    • Anthony Hornback
  • For sale 1g Flip up covers
    Pair of black flip up covers
    • Anthony Hornback
