Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > General > Tech Article Archives > Articles: Parts Fabrication
Add to this Article
LinkBack Thread Tools
Old 06-18-2007, 06:55 AM   #1 (permalink)
Proven Member
Region: Gulf Coast
Classifieds Rating: (0)
Reputation: 4wd-Eclipse is an unknown
2 Oil Catch Cans Setup ...
Needed Parts:
1. Two metal custom made oil catch cans (8”long X 2.5”diameter)
2. 1 piece of 3/8" KynarŪ Liquid/Gas Check Valves (usplastic.com part # 64175)
3. 7 pieces of female 3/8” NPT metal weld-in bungs (fabricated)
4. 2 pieces of female 3/8” NPT aluminum weld-in bungs (Summit part # SUM-220072)
5. 5 piece of straight 1/2” Hose Barb to 3/ 8” male NPT (Summit part # PRM-15153)
6. 1 piece of 90 Degree 3/ 8” Hose Barb to 3/ 8” male NPT (Summit part # TRD-2271)
7. 2 piece of 90 Degree 1/ 2” Beaded Hose End to 3/ 8” Male NPT (Summit part # EAR-984208ERL)
8. 1 piece of Steel Internal Allen Plug 3/ 8” NPT (Summit part # EDL-9127)
9. 3 feet of 8 mm ID HTS Silicone Vacuum Hose from ExtremePsi.
10. 5 feet of 10mm ID HTS Silicone Vacuum Hose from ExtremePsi.
To avoid touching the hood, both 90 degree fittings and aluminum weld-in bungs were modified to be less than 35mm in height as illustrated in last pic.
Offline
Related Auctions
Sponsored Links
Add to this Article
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are Off
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.08936810 seconds (65.84% PHP - 34.16% MySQL) with 10 queries
