Mounting Palm Pilot in 1G
After struggling to try to mount my palm pilot I ordered up this bracket from work and installed it. Its a profit bracket used for mounting cellphones when installing hands free kits.
Profit bracket part number. DG-56-95 its for a 94-99 dodge neon
1 Short Screw
Velcro
Instructions.
Remove Center panel Clip thingy (sorry dont know what its called.) Pic 1
I positioned my bracket so I could still spin my heat controol and press the rear defrost button. I'm not sure if this bracket will fit if you have a rear winshield wiper button.
Screw the bracket in place once you have it where you want it.
Put the plastic center panel clip thingy back in place.
Put velcro on the back of your palm and some on the bracket . Then your good to go.
  • For sale 4G63 Used FP 4G63 Turbo Manifold
    Used FP 4G63 Turbo Manifold removed from 1G Talon. Looks okay, needs a cleaning. Did not see any...
    • Badge023
  • For sale 2g Fiberglass Fenders
    2g Fiberglass fenders. Overall good condition. $50 + Shipping/FeesFor faster response Text...
    • 1SlowPOSEclipse
  • For sale 2g 97-99 Mpi relay
    2g. 97-99 Mpi relay. Many don’t realize the later 2g doesn’t use the same mpi as the 90-96...
  • For sale 2g 2g window moulding
    2g pass side window moulding. Rubber is in decent shape. Has one dent. Front plastic end cap...
  • For sale 2g Mahle Power Pak Pistons
    2g Mahle Power Pak Pistons, factory bore $350.00 Brand new with wrist pins and extra set of...
    • jmt2028
