Rob98GST
- 60
- Dec 23, 2003
FT. Worth,
Texas
This is a picture of the drivers side window on my GST (notice all that seperation from the weather stripping?). When I bought the car I could tell that the original window had been broken out because little pieces of glass came out from the bottom of the door whenever I shut it.
The problem is, it scratched the tint on my door, and it didn't stay in track when I tried to roll it up.
http://www.imagestation.com/picture/sraid100/p478a3d186543fe0058f98b0bf1fc3810/f9e44d65.jpg.orig.jpg
On the window diagram - the location I have circled in red wasen't connected at all, the bolt was in the guide track, just not connected (this was the bolt that scratched the tint on my window). I am not really sure why it wasen't connected. I thought that perhaps it came loose, but I looked around inside the door, and couldn't find any loose parts.
I reconnected this piece to the glass guide track using two washers on each side. It now roll's up just fine, but only with the door opened. If I try and roll the window up with the door closed, it gets out of djustment. It roll's down just fine though.
Before I reconnected the piece to the glass guide track, the window sat in the door normal with the door opened. It's just now that I re-connected the window the way it should be that it's like this. I am pretty
sure it's because the window is connected to the guide(the way it should be in the first place), and it's pulling the window away from the outside of the door.
I was just curious if anyone has changed out a window on a 2g and seen something like this. I have changed out 3 windows on 1g's, but they are quite a bit different. I don't want to have to take the car to the dealer and have them look at it. If anyone has ANY idea's please let me know.
Thanks.
