Fattie92
- 607
- 3
- Dec 20, 2003
Waukegan,
Illinois
Ok well i had the alternator bench tested (cold) and it checked out fine. I also had the battery tested and all was good there. now today my low coolant level, batt. , and brake light come on. They are all dimmer then normal. If i pull the parking brake, the brake light gets brighter like normal. I cleaned the connections to the batt as well. I read another post on here and it siad that it ended up being his alternator..... but mine tested fine the other day..... any ideas?
they gotta test your Alternator while its in your car!
