Important Q- Dual Hum CF hood fit 420a Turbo?
InfamousEclipse
1,928
2
Jan 11, 2003
Tri- Cities (c³), Washington
I have a turbo 420a with my turbo near the middle of my engine bay. I like the Dual Hump CF hood but wonder if there is any clearance issues?
I will post pics when im off work so you guys can get a better idea
The hump is for the cam gears, and actually it's for the drive belt cover. Apparently if you run without a cover, you don't need the hump. I can't imagine your setup sitting up high enough to need clearance.
Just had to make sure since the turbo itself seems to sit higher up then the valve cover and its in the front- ofcoarse hood slump down in the front. I'd just feel real dumb if I spent $ on a hood that didn't fit, nor have I seen anyone with this settup so I had no wya of knowing
