Help Remote Start with Turbo Timer on MT
Custom85Camaro
Ok fist off i have done a search and didnt find what im looking for.
Right now I have a HKS turbo timer installed on my manual transmision eclipse and I need to install an alarm. So my question is which alarm with remote start would be the best and will work with my turbo timer. I am looking for an alarm that will arm with the turbo timer running, if i remember the Viper alarms allow this. Thanks for you help.
Please dont tell me to go to Circuit City, Car Toys, Best Buy so on and so on... Been there done that....
So long as the installer knows what he is doing, any alarm will work with any turbo timer.I have experience with nearly all brands, code alarm is the only one I can think of that won't arm with the ignition on.But a good installer could make it work(by putting a relay in the alarms ignition sense wire).
I don't recommend using any remote start with any manual transmission.
i have a remote start on my car. 99% of the remote starts we sell have a turbo timer built into them, the only thing you can do is wait till the car shuts off and then arm/lock it. other wise it will go off.. but you can run a turbo and remote no problem
  • Wanted 2g ABS - Left side harness brackets
    Looking for the metal brackets for left side ABS wiring harness. Sensors not needed
    • Justin DuBois
  • For sale 2g 2GB CAS Assembly ( Complete )
    2GB CAS Assembly ( Complete ) $85 + shipping and paypal feesYou must be registered to see element.
  • For sale 2g 2G Clock Spring, Wiper Stalk, Turn Signal Stalk
    2G Clock Spring, Wiper Stalk, Turn Signal Stalk $35 + shipping and paypal fees* removed from...
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
