Installed headers with pics
Charles1
160
Oct 24, 2003
Ok its done but I got some questiond for you all.
I redid grounds and I will also post those pics also. I also redid the power wire from the battery to the starter. I gutted out the cat and reinstalled it. Now the car idles really bad after gutting the cat. Is there anything I can do to stablize it? Second my car keeps blowing fuses. Its the 30amp engine fuse and its on the top left I will post a pic of it too. Does anyone have a clue what can cause this. I rechecked all the wiring nothing is touching and everything is secured. The more I press on the gas pedal the brighter the fuse get and it blows up. There was a wire on the cat that is kept in place by a smal screw I put that back but it was weird looking it looked like a shoe lace. Can anyone help me? All the wires are fine and its only that fuse what else do I have to check.:confused: the car is a 95 talon fwd.
*EDITED since its hard to read*
this one of the ground i redid the intake manifold one
any one have info on my fuse issue
The top left fuse is the one that always blows. Its the engine fuse. 30amp what can be my problem? Also about the bad idling how can I adjust that?
i could be wrong but if this is the positive batery terminal,i dont think it should be grounded to the chassis. If the power wire is going to the chassis it would be sending power through the entire car and it could be what is blowing the fuse.
P.S.
if that picture is of the negative teminal or if that wire is going to a amp or cap, ignore everything i just said.
