What is this hose?
EclipseMGP
Jul 30, 2002
Obviously a drain hose but where is it coming from. The clear hose is the hose that leads from the drain from the two holes in the liftgate. My arm is too big to follow the BLACK hose. Where doesn't the black hose go? This is important because I have a leak that is running into the spare well.
Edit: Sorry i should be more specific. This is right above the passenger side rear wheel well. I removed the interior trim to get to this.
i believe the black hose is a drain for the hatch. it should come out under the rear tire wheel well. i knoced mine out and the spare tire filled with water. not sure what the other one is for. it may be your sun roof drain.
Nope, the semi-clear hose in the forground leads to the hole in the hatch. THis one runs up and behind the fender and then I can't trace it any further. Chiton's has nothing on it.
i also have chiltons, and i remember not seeing any info on those tubes either.
Ah I got it. Sunroof. I bet the hose runs all the way up to the sunroof. I'll have to try it.
