Stupid question? where does the 10 disc cassette go in the trunk of a spyder
tunerdoc
41
Jan 5, 2003
north kingstown, Rhode Island
Can any one help with the location for a 10 disc cd.
I have a 97 syder and it is not clearly apparent were it is suppose to go.OMG
Pardon my guess, but I think it's the right-rear, similar to the hardtop. If you have the factory mount, there will be threaded holes for it. Have you found the DIN cable and power supply?
Take off the back of the back seat to get to the compartment where the top goes down into. You will see part of the metal frame with threaded holes. Your din cable and power supply cable should also be in this area (either in the compartment, or under the back seat, unless previously removed.) The rear of the seat is held on by 2 bolts (either 10MM or 12MM) then it slides up and out.
Thanks guys I found it after I took off the inside trunk panel.
Works like new. Any one have the mounting brackets that hold it in place.
Doc
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • Wanted WTB MSD DIS 2 bypass plug
    As the title states.You must be registered to see element.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
    • dhssoccer24
