My window sags like a 50yr old woman's boobies
doodie
1,025
Aug 11, 2002
Brooklyn, New York
When I try to close the door with the windows up, its almost impossible to close the door from the inside. If I'm outside, I can lift the door up a little bit and slam it shut fine. But when I'm inside the car, it makes it really hard to close the door. The door sagged a little causing it so hard to close. Is there anyway to fix this?
Get some implants.
Maybe there is something wrong with the door rather than the window. Don't know.
You just wanted to say get some implants didn't you? Well, anyways, the door closes much easier with the window down 1/2" so it the top piece rubber pushing it down a little. But even with the window down, I still can't close the door with ease like the passenger side.
take to a pro and then have them give u a quote and they will tell u whats wrong then take home and fix urself ;)
I have the same prob with my driveside door. Please let me know what you come up with as the problem. Thanks in advance.
Jester
are all the door hinge bolts tightened all the way. My friends truck did that and we found out that one of the botls on the top hinge was stripped and causing it to sag alot. check and see if that's the problem if not then you mihgt need a new hinge itself as it might be bent.
