Indiglo Gauges **Need Help ASAP**
BD1
1,266
Mar 10, 2003
Fairfax, Virginia
I ordered BOMZ indiglo gauges, anyways its all assembled and they are in the car right now, everything works fine and such, and all the face plates are connected HOWEVER the switch to turn on the lights is dangling from under the steering wheel, I need to find a power source I can attach it to so I can manage the lights, please help.
Run a switch wire to 1 of your fuses for interior lights in the fusebox? Or run it outside, like I have mine, to the parking light fuse. They come on whenever you turn your parking lights/lights on.
or an easier way if you are wanting power to them to like dim them and stuff is to connect to the lighter. all you have to do is take side panel off and splice into the wire that is farthest away from you when you are looking directly at it from the sides. that will come on when you turn the parking lights on as well. good luck.
sept indiglos dont really dim VIA the dimmer switch all that well. but ya thats were mine are wired -- for power - i also have an upside down hazard button in the blank spot in the center vent to turn them off if i want them off.
