Fog light install on a 96 ESI
JReynosa
73
Nov 5, 2002
Las Vegas, Nevada
I bought used fog light from some one for my 96 ESI. All the wireing appears to be there but they dont turn on when I turn on my head lights. Is there a switch that needs to be installed some where? Any help would be appreciated.
You need a switch, the factory foglight switch goes on the left of the tach, in the middle hole- the top is for the cruise control, the square one on the bottom is for the electric mirrors. I don't know if you already have the wiring in the factory loom or not, but pull the panel there and check. You'll also need a fuse and relay, and I _think_ that'll make you good to go.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33695&item=2425401557
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=40017&item=2425771969
All of the fuses and relays are there. I checked behind that panel and the wiring harness for the switch is there also.
my car has the wireing for the switch but theres no relay or fuse and theres no contacts down in their holes where they go in the fuse box either is there any way i can make these work?
if i have to just wire them up my self is there a way i can hook them up so they shutoff when i turn on the high beams but they can be on with the marker lights or the headlight lows?
