Spray on wax?
Knoob
1,190
5
Dec 10, 2002
Ridgeland, Mississippi
hey what is that new waxes name that just came out
says that you spray it on a wet car and then dry the car and it waxes the car for you....
what is the name of that and where can i get it at? searched walmart for it and couldnt find it.....
Eagle One, Wax As You Dry. Works excellent on a well prepped surface. However, if you car needs waxing or has never seen wax for a long time, this will not solve your problem.
agreed with whats said above. i use it inbetween waxes. but i dont use it as a subsitute. make sure the surface is really wet before spray it. other wise it gets real smeary and messy. usually after i wash my whole car ill re-spray the whole car again then put the eagle one on one panel at a time.
I use McGuiar's brand spray wax, and that is used on a dry surface. Therefore, you don't have to worry about it smearing, etc. and I think the results are great...
And yes, I bought mine at Wal-Mart ;)
