How To Change Od Button To Toggle?
Eclipse419
92
Nov 6, 2002
i recently took my my autostick and put in a shift knob....so now i basicly need to find a place to put my overdrive button a..has any1 ever made a overdrive button to a toggle swtich.?..this guy i kno install alarms n neons...but hes not sure wut kind of toggle switch works for OD button....does any1 kno..wut kind of toggle switch to use and have a pic of it..? thanks!
Does the stock switch actually switch, or does it signal a relay to toggle? Either way, you should just be able to mount a switch like the 1G power/economy switch on the face of the console, such as next to the cigarette lighter.
I looked at my switch awhile ago and if I remember correctly, there is only two wires that go to the switch. If so, you can use any toggle switch. I'd go with a heavy duty one though, Imo. How do you take it out of park and stuff? do you need to push a buuton to unlock it?
I thought your car was an automatic. On mine you need to push the button on top of the shifter down to get the car ot of the "P" position.
