door panel rattle
rockice
103
Jan 31, 2003
Hamilton,
Hey I was wondering how to tighten the outside door panel my passenger door does not rattle but the drivers door does I was wondering how to tighten it. It is not the window I tightened that up it is the metal and I could not figure out how to tighten it up any help appreciated thanks.
theres another thread on this, i dont feel like finding it tho. roll your window 75% of the way down, and take off your door panel, and get the speaker out of the door. If you look up to the left inside the hole that the speaker fits in, youll see a metal bracket holding onto the window, which is a 10mm socket. take that off, pop out the bracket, and where the plastic piece is, get some pliers and squeeze it together. then reinstall it, and your windows definately wont rattle much anymore. i did it and its a great help.
its not the window it is the metal door and the mirror shakes to while im driving and i want to know it there are any bolts to tighten thanx for the reply tho
is anyone sure about it being one piece has anyone had this problem ???? i hate driving around with my mirror vibrating like crazy
Pop the cover off the delta trim, tighten the 3 nuts that hold the mirror on. Don't go nuts with it.
For the door rattle, take off the trim panel and the plastic, and go for a drive and find out what's loose, tighten.
