reverse indiglos
pozz24gs
196
Apr 7, 2003
anyone know if these gauges are made for the non turbo cars w/ a 9000 rpm tach
http://procarparts.com/store/displaydetails.cfm?pid=MIT-ECLP-9599-RIG-NT
if not, would i be able to get these and have them line up right even though i have a 9000 rpm tach. i dont think so, but my friend told me they would. If they dont, does anyone know if i could buy the turbo set and the non turbo set and take the turbo tach and speedometer and use the non turbo temp and fuel gauge and have a complete working set? please help me someone
i know the engine wont rev to 9, but i want to make sure that my tach reads what the engine rpm really is
Hey, how about not buying indiglo gauges? They kill night vision, which is useful when you are driving in the dark and need to see what is ahead of you.
Do you drive at night? Do you also like seeing the fleeing pedestrians in front of you?
yes i drive at night and i have no problem seeing at night but thanx for your concern
So you have no problem seeing over the indiglo lights in yer dash? I do, as do most of my buddies (Micah has them in his 200sx, and they mess us up).
nope, driven in cars with reg. indiglos and reverse indiglos and had no problems yet.
Just get basic reverse indiglos, you can see fine at night and they look better than the ones you posted
Yes thats pretty similar to the ones i have, they light up a nice elctric blue color instead of that ugly blue indiglo color
but does anyone know if the ones w/ 8000 rpm tach will be accurate? plus where did you get your indiglos?
They're acurate, just mounts over the top of the stock ones.
I got mine off ebay for 35$
how are they accurate if they only go to 8000 rpm and mine goes to 9000? sorry if im being a pain, but im lost on this subject
how can they be accurate if they only go to 8000 and mine go to 9000 rpms? sorry for being a nag
i just want to know now if i get the 8000 rpm ones, will it still be accurate since i have the 9000 rpm tach
From what I have seen the 8k tach will not be accurate. In the pictures the 8k has larger spacing and ends in the same position as the 9k. I think the 8k is for autos and the 9k for standards, with that in mind you may want to call them and see if they have the style you want in 9k (if you haven't already).
I have reverse indiglos and do not have trouble seeing at night and if I did they come with this thing called a dimmer.
alright thanx. looks like im out of luck. i want those specific ones, so should i buy the turbo ones and the non turbo ones and try to rewire them, or should i say screw it, i have an aftermarket tach, i dont need the one in my dash
If you really want to purchase two sets then yeah. The turbo tach should be the same layout. You would use the non-turbo fuel, temp, and speedo gauges. They should all have the same plug ends so there shouldn't be any rewiring (at least I wouldn't think so). You might even see if they would put a turbo tach in place of the auto so you wouldn't have to buy both kits.
