interior stock car look!
That is hideous and would drive me nuts.
Can go with "simpified interior" similar to NASCAR. You will still have a dash, but most of the structural components will also be visible. Keep in mind, it is ILLEGAL to tamper with the VIN plate on the dash, so you will have to think of a way around that.
Less weight! Haha but seriously, if you like it keep it, or make a custom dash like the one above
I could drive like that.. However, Id go crazy without any warning gauges temp, oil, fuel etc.. Perhaps taking the wire harness out of the dash and tuck it and make a bracket to hold the stock cluster or make your own..
I couldnt do this with my spyder, the outside is far too pretty! Now, if I were to start modding my 1g, for sure.. Thing is a pile and would be a total sleeper.. If the cops were to say something about it tell them the dash is broken or sun damaged and is out of the car being repaired. :idontknow: might still get a ticket but could be lesser of one for tampering with the vin..
Im up in the air about it. Mainly because disconnecting the rats nest of wires going to aftermarket gauges would be a PITArse.
so really it weighs less but other then that if its your daily you take away all the comfort. you would have no hvac or evap so unless you live in the perfect climate you will either sweat to death or freeze. then if you have a problem where your car starts to overheat you cant even turn on the heat to reduce colant temp. just sounds kind of unpractical. just my opinion.
