SetH
- 416
- Jul 30, 2002
Michigan
I've installed a few HU's before, but now I'm really puzzled. There was an aftermarket cd player in my car to begin with, and I recently bought a sub, amp, new speakers, and new HU. I wired everything up, set up the amp and sub in the back, and plugged them up to the HU that came with the car. Things seemed to work well, so I went ahead and took out the old head unit, and cut all the wires and connected them to the harness for the new head unit. When I plugged it in, I got no power. I then decided to try and narrow down possible problems, and hooked the old head unit back up. No power on that either. I checked the fuse, it was fine. I figured that it must be a problem with the battery wire because it would at least power on if all was ok. I tested the connection on the end of the harness that hooks up to the head unit, and it was receiving full power. So I have a good fuse, a good connection, and 2 head units that won't power up. I'm pretty much puzzled, and I am hoping someone out there can help me out.
Seth
Seth
