vassil
- 82
- May 22, 2002
Winona,
Minnesota
Hello Gentlemen,
I just got three 60mm gauges and I am in the process of achieving the 'stealth' look. The idea is that the holes for the limate controls in the 1G dash are about 61-62mm and a perfect fit for gauges. I took the whole thing apart and the problem is that the cables are not long enough to relocate the three knobs below the stereo. I saw it done on a VFAQ that had nothing to do with this. I tried bike cables, Harley Clutch cables,
even a John Deere lawnmower throttle cables. They do not work because they are too soft because they bend a lot.
Has anyone here done this, and if yes, what cables did you use ... or do you gentlemen have any suggestions?
I would greatly appreciate any replies.
Below is the URL of the car I saw it in.
http://www.vfaq.com/proj-pics/shifter/shortshifter/shortshifter-20.jpg
