EUREKA! Auto shift knob install VFAQ!
So how are you supposed to connect the wires? if red is for power, then I assume it has to be the positive terminal, is it connected to the OP power light?
red wire --------------
black wire ------------
yellow wire ----------
or is the power wire joined with the light wire and when you close the switch, it connects to the ground?
When you close the ground, the O/D kicks in and the light goes out. The light says O/D off. You don't need the light. Mine doesn't work and I have no problems telling when the car is in or out of OD. You have a tach, use it. imo, it's better to not have a light than to have a shift knob like everybody else. I am glad that people are finally doing things to change this now tho. You can probably just run the yellow in with the power wire with a crimp connector. That'd be my guess.
9d9, what do mean by closing the ground? is is similar to the horn ground? when it is connected tot he chassis, its considered close? I saw a diagram on the web for a borg warner auto tranny and there, the light is connected to the ground and its connected to the power wire.
So I basically have to make a switch that closes the circuit? red on one end and balcka nd yellow on the other?
DSMhelex, is a MOMO automatiko, www.momo.it, you can check it there, I used Tamiya silver paint, the kind they use for RC cars, basically sprayed about 5 coats on it, wasted te entire can and topped it with 3 coats of clear pylox
  • For sale 420A 420a block & EGR/ FUEL RAIL INJECTORS
    90PSI compression test. Possible damaged piston rings, unsure. Possibly good for a...
    • Stizzydrew
  • For sale 420A OEM 420a throttle body
    $40 + shipping + fees (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a intake manifold
    $80 OBO + shipping + fees. (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a thermostat housing
    Oem thermostat housing 420a $20 + shipping + fees.
    • Stizzydrew
  • For sale 420A NVG T350
    New venture gear T350 M/T 420a
    • Stizzydrew
